The hidden cost of PDFs in utility operations
When critical utility data lives in PDFs, AI and automation can't reach it. Discover the hidden cost of unstructured document workflows.
Key takeaways:
  • Utility data, such as inspection reports and maintenance logs, often sits in PDFs that automation and AI tools cannot read.
  • PDF-based workflows are historically manageable, but modern systems and AI need machine-readable data.
  • What looks like an AI capability problem is often a data accessibility problem: models fail because they cannot see records trapped in documents.
  • The cost shows up three ways: hidden re-entry labour, degraded data quality from transcription, and a hard ceiling on AI readiness.
  • Automating extraction of document content into GIS and asset management systems is often the precondition for predictive maintenance.
Most conversations about utility data go straight to the hard technical challenges: SCADA integration, GIS complexity, the slow convergence of operational and information technology. Those problems are real. But a simpler, more pervasive one rarely gets named, and it may be doing more to hold back AI ambitions than any of them.
An enormous amount of utility data is unstructured and lives in PDFs: inspection reports filed by field crews, engineering studies from consultants, asset condition records from site visits, maintenance logs submitted by contractors. They represent years of operational knowledge about the condition and history of physical assets, sitting in formats that automation and AI tools cannot reach.
This matters more now than it did five years ago because the gap between what utilities want to do with their data and what their data will allow has widened. Predictive maintenance, automated risk scoring, and AI-assisted inspection analysis all assume the underlying data is accessible and machine-readable.
What lives in PDFs across a typical utility company
The documents that pile up across a utility are often the most current and detailed information a team has about an asset. The problem is that being detailed and being accessible are two different things:
  • Inspection reports. When a crew examines an asset, they record information like its condition, vegetation encroachment, defect ratings, and maintenance recommendations. The report is the most up-to-date record of the asset’s current state, yet it lands as a PDF. Unless someone re-keys it, none of it reaches the GIS or asset management system where it would be used.
  • Engineering studies. Load flow analyses, fault studies, and capacity assessments hold the context that drives capital planning and risk modelling. Delivered as finished consultant PDFs, the conclusions get read once, inform a decision, then sit in a folder.
  • Asset condition records. Manufacturer data sheets, commissioning records, and inspection certificates are often the only surviving source of original specification data for aging infrastructure, and for equipment that has been on the network for decades, they may be the only record of its baseline.
  • Maintenance logs and work history. Contractor reports, repair records, and test results are the closest thing many assets have to a continuous maintenance history, exactly the data predictive maintenance models need, and exactly the data that tends to live outside the asset management system.
If a planner asks a straightforward question about an asset’s history, such as when it was last inspected, what was found, or what work was done, the answer is hard to produce because the record is in a document nobody can query. The information exists, but it’s not reachable by a machine.
Why this was manageable before AI, and why it isn’t now
PDF-based workflows have existed for decades, and utilities companies built functional habits around them. Engineers know which report to look for and where it is filed, and analysts know how to open it and re-enter the number they need. It works, but it’s slow and manual.
AI-assisted operations break that arrangement in two ways:
  1. AI models require structured, machine-readable inputs, which is a very different thing from a scanned inspection report. The records holding the richest operational history are the ones most invisible to the tools meant to analyze them.
  2. Automation. Real-time risk scoring, automated work order generation, and predictive maintenance need data continuously, not retrieved by hand. A workflow that hinges on an analyst typing numbers into a spreadsheet cannot feed a system that expects a live data stream.
A company that can’t build a reliable predictive maintenance model because half its inspection history lives in PDFs might think this is an AI capability problem. But this is just a document management problem that has become an AI readiness problem: the model fails because it is reasoning about assets whose recent history it can’t see.
In Safe Software’s State of Utilities research report, 66% of utility professionals cited reduced data quality and lost productivity as the biggest business impact of their data integration challenges, a figure that predates the current wave of AI adoption pressure. The drag from disconnected and inaccessible data, including data trapped in unstructured formats, was showing up in daily operations before anyone tried to layer AI on top of it.
The real cost: productivity, data quality, and AI readiness
The case for addressing the PDF problem rests on three costs that compound:
  • Productivity, almost entirely hidden. Engineers, analysts, and GIS professionals spend hours manually extracting, re-entering, and cross-referencing document data. This accumulates across every team that touches a document-heavy workflow.
  • Data quality. Every hand-keyed number is a chance for a transcription error, an inconsistent format, or a missing field. A record populated from a PDF is inherently less reliable than one from a structured feed, and a model trained on inconsistent records inherits every inconsistency. The same State of Utilities research found 77% of utility professionals named data quality and standardisation as their top integration challenge, and PDFs feed it directly, because their content cannot be standardised without manual effort or specialist tooling.
  • AI readiness, the forward-looking one. A company that has not addressed its unstructured data problem cannot fully realise its AI investments. You can buy the predictive maintenance platform, hire the data science team, and stand up the infrastructure, and still get a partial result, because the model works from a partial view of each asset.
As Forrester framed it in 2026, in the age of AI, data quality has become one of the most critical capabilities for maintaining trust in both data and AI across modern enterprises. The reliability of every AI-driven decision a utility makes now depends on the accessibility and quality of the data underneath it, and unstructured documents are one of the largest remaining sources of both problems.
What addressing unstructured data makes possible
Once document data is reachable, inspection data can flow directly into GIS and asset management systems, so a condition record updates from the field report instead of waiting for re-entry. Engineering findings can inform capital planning models without an analyst extracting them by hand. Maintenance history can join sensor readings, SCADA, and weather data to give a predictive maintenance model the full picture of an asset rather than a partial one, which matters because effective predictive maintenance depends on combining real-time sensor data with historical logs and the unstructured documents that explain what the sensors alone cannot.
Getting there is a data integration task: reading content out of document formats and delivering it, structured and validated, into the systems that need it. FME can automate the extraction and transformation of data from documents, pulling text and tabular data out of PDFs and writing it into GIS, CAD, databases, and asset management systems. Connecting document content to enterprise systems is the kind of repeatable pipeline that removes the manual re-entry step for good.
Conclusion
The PDF problem doesn’t look like a data challenge. It rarely features in digital transformation roadmaps busy with SCADA, GIS, and OT/IT convergence. It hides in plain sight because everyone has learned to work around it.
But for many utilities companies, it’s one of the most immediate barriers between how operations run today and the AI-assisted future they are building toward. The reports, studies, and logs sitting in document folders are the operational context AI tools need, and right now they are unreachable. Addressing that is a precondition for a successful AI strategy.
Learn more
Want to learn more about how FME can help you connect your utility data? Book a personalized demo with a utility advisor today!
Ask a Utility Advisor
Safe product icons
