Adventures in FME Server Administration
When an FME Server administrator is trying to get out of the office to head out on a rip-roaring archaeological adventure, there are only two things on his mind
When an FME Server administrator is trying to get out of the office to head out on a rip-roaring archaeological adventure, there are only two things on his mind – getting the job done faster and better. FME Server 2012 helps accomplish both.
Only have ten minutes worth of sand left in the hourglass before the door to the secret passageway slams shut forever? You’ve got time to install FME Server. With the new Express installer, a complete installation takes less than ten minutes. And easier distributed installation shaves even more time off of your IT load. If you’re really in a rush, use the new FME Server AMI to get going in even less time – with no infrastructure requirements.
Being pursued by a horde howling for data? With new Microsoft Active Directory® integration in your back pocket, you can manage them with ease. Applying security rules and roles has never been easier, and gives tighter and more granular control over user and author access.
FME Server 2012 – spend less time on administration, and more time on your next quest.
Safe product icons
